mikeulator's avatar
mikeulator
R7500v2 slower speeds for all devices vs router speed test
I've been through several posts on this forum and none of the items in them have fixed my issue.  I'm experiencing speeds slower than expected for any device (wired or wireless) connected to the rout...
  • mikeulator's avatar
    mikeulator
    Dec 02, 2016
    I ended up going the factory reset route since no one had responded yet.  After a factory reset it was still bad but after rebooting the router after that everything was great.  I then reimported my backed up settings just to see what would happen... and it's still good even after rebooting the router.  So maybe there is a bug in the router and after a certain condition happens something goes haywire?  I don't recall always having problems and I've had the router since April.  Maybe it was there and I just wasn't doing anything to notice it as much.  Either way it seems to be fine now and it apparenlty isn't related to any setting.
    Thanks for the reply James.
