jtizzle247
Sep 04, 2021Aspirant
R7500v2 wireless working wired is not
Hello all, A couple days ago all of my wired connections stopped working. Wireless is working fine. I use all 4 ports on my router and none of them can connect to the internet. The lights are bli...
- Sep 05, 2021
jtizzle247 wrote:
The modem is a Calix 726GE-I
It looks like a standard Optical Network Terminal rather than a router combo, but the presence of four Ethernet ports on something like that is new to me. It usually denotes a modem/router combination.
Some Google pages talk of it in router terms which takes you into double NAT country.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
And this converstion refers to a router:
RAX70 requires me to login to wifi repeatdly - NETGEAR Communities
michaelkenward
Sep 05, 2021Guru - Experienced User
jtizzle247 wrote:
I use all 4 ports on my router and none of them can connect to the internet. The lights are blinking constant white with the exception of 1 orange, but that is because that connected device is off.
It may be that the LAN ports are connected to the Internet – that's why the lights are flashing – but there is a problem with the devices at the other end of the LAN cables.
What are those devices?
jtizzle247
Sep 05, 2021Aspirant
Thank you for responding.
3 desktops and a TV. They all stopped working at the same time via ethernet. 1 of the desktops and the TV have wireless capability and connect to the router fine.
- michaelkenwardSep 05, 2021Guru - Experienced User
What do the desktops say when you try to connect?
Windows can be picky about connecting to "new" networks. But it usually throws an error of some sort to warn you.
Tried running the TV through its setup process?
- jtizzle247Sep 05, 2021Aspirant
No errors at all. With my desktops, the ethernet adapters say "unidentified network" and have APIPA addresses when viewed through ipconfig. The TV doesn't see any wired network available.
Forgot to mention that I did try the setup process for the TV and says there are "no wired networks available".
This is just so weird that they would all stop at once.
