somevegasdude
Oct 10, 2022Tutor
R7540 no internet access after factory reset
Firmware: v1. 2.0.92_1.0.1 Windows 10. After factory reset, router shows connected to internet (white light), but tray icon shows "no internet access". Cannot access internet from wifi or wired conn...
- Oct 11, 2022Thanks! I did all that too. Same issue.
It turns out that two of the ports were bad on the router causing excessive packet loss over 80%. Using a different port fixed everything. The short must have been impacting wifi too because it's all good now.
The ISP tech support has me ping the gateway IP, which exposed the problem. He suggested a new router, but I found that switching ports worked.
Strange that this became an issue at the same time that I did the reset...
somevegasdude
Oct 11, 2022Tutor
michaelkenward
Oct 11, 2022Guru - Experienced User
If you need more ports, an unmanaged switch would cost a heck of a lot less than a router.
Sod's law. you did well to track that one down.
