jangodog
Dec 26, 2024Aspirant
R7800 — Nighthawk X4S
Hi. Anyone got this latest firmware V1.0.3.92 on netgear Nighthawk routers and does it cause any issues?
Dec 26, 2024Guru - Experienced User
Can give it a try. The R7800 is now EoL so won't see much updates for this model router.
Best option would be to use Voxel FW as he maintains a good alternative FW version for the R7800, R8900 and R9000 model routers. I see he has something new this month for it.
Kitsap
Dec 26, 2024Master
FURRYe38 wrote:Can give it a try. The R7800 is now EoL so won't see much updates for this model router.
jangodog wrote:Hi. Anyone got this latest firmware
Here is the Voxel link: https://www.voxel-firmware.com/Downloads/Voxel/html/index.html
Be sure and review the documents under the Readme tab in the upper right hand section.
