jbs2022's avatar
jbs2022
R7800 - allow guest on home network
I have a R6700 set up in my garage and connected to the cable modem.  I have the wifi turned off.  In my living room I have a R7800 set up as an AP.  It is connected to the garage router by ethernet....
  • antinode's avatar
    Mar 02, 2020
    > I have a R6700 set up in my garage [...]
    > [...] I have the wifi turned off. [...]
       Why is the R6700 is the garage?  Is anything connected to its LAN
    Ethernet ports other than the R7800?
    > [...] the cable modem. [...]
       Not a very detailed description of that device.
    > [...] In my living room I have a R7800 set up as an AP. [...]
       That's why its "guest network" stuff is disabled.
          https://kb.netgear.com/26765/
    > [...] I would like to have the guest network for visitors to use wifi
    > but I do not want them on my home network. [...]
       Strictly speaking, "guest" clients are not on a separate network, but
    there are firewall-like rules (enabled by default) which can limit their
    ability to communicate with non-guest client devices.  (Those
    firewall-like rules are implemented in the router section of the device,
    which is why that functionality is lost when the router is configured as
    a wireless access point.)
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for check-boxes
    like "Allow guests to see each other and access my local network" (in
    the "Set Up a Guest WiFi Network" section).
       The real mystery is what the R6700 is doing for you (other than
    causing trouble).  Running another cable from the garage to the R7800,
    and using the R7800 as the main/only router might simplify many things.
       You could run coax in, and put the modem near the R7800-as-router, or
    you could run Ethernet from the modem to the R7800-as-router.  If there
    are client devices in the garage, then you could run Ethernet from the
    R7800-as-router (LAN port) back to the garage.  For multiple devices in
    the garage, put an Ethernet switch out there, or the R6700-as-WAP (with
    its wireless-network radio(s) disabled?).
       As usual, many things are possible.
