Hoochee's avatar
Hoochee
R7800 - connect USB hub?
Someone point me to the post if there's one already.   Windows 11 PC   If I have four 3.5" USB HHDs connected to a hub, and connect that to one of the USB ports on the router , can I access them ...
  • Hoochee's avatar
    Hoochee
    Dec 22, 2021
    Multiple external USB drives connected to a USB hub, connected to one of the USB ports on the router, are recognized as individual drives by ReadySHARE. Running Win 11, File Explorer sees them as a single volume, but I can Map Network Drive, enter the UNC Path for one of the drives and it's found as a separate. Interstingly, when I enter the Path and click Browse, in the "Browse For Folder" window Win 11 shows "readyshare" as a Network location. Within File Explorer it doesn't show that way.
