Hoochee
Dec 15, 2021Aspirant
R7800 - connect USB hub?
Someone point me to the post if there's one already. Windows 11 PC If I have four 3.5" USB HHDs connected to a hub, and connect that to one of the USB ports on the router , can I access them ...
- Dec 22, 2021
Multiple external USB drives connected to a USB hub, connected to one of the USB ports on the router, are recognized as individual drives by ReadySHARE. Running Win 11, File Explorer sees them as a single volume, but I can Map Network Drive, enter the UNC Path for one of the drives and it's found as a separate. Interstingly, when I enter the Path and click Browse, in the "Browse For Folder" window Win 11 shows "readyshare" as a Network location. Within File Explorer it doesn't show that way.
Hoochee
Dec 22, 2021Aspirant
michaelkenward
Dec 23, 2021Guru - Experienced User
This is not my experience. But with a slightly different arrangement of USB drives.
My "hub"is actually a pair of USB ports on the front of an 8TB Seagate USB drive. So I manage to have five drives connected to an R7800 router.
One 4TB WD Elements drive + One e-Sata drive + 8TB Seagate USB drive with two USB drives attached.
All of these are clearly visible in the ReadyShare branch in Windows 11 Explorer.
Oddly, I also have a USB CD drive that, no matter how I attach it, hub or directly plugged in, does not show up as a drive in Explorer. It does appear when I enter the drive letter into Explorer.
