Dreep
Nov 27, 2020Aspirant
R7800 - dimensions wall mounted with antennas
Hello, I'd like to buy an R7800 router but I'm not sure if it fits considering the size...
Can anyone that has it, please check the overall width and height of the router when wall mounted with all the 4 antennas installed and pointed up?
I tried to look in the documentation, but I can only find the dimensions without antennas.
Thank you very much,
My unit was purchased three years ago. Would presume the dimensions have not changed drastically since then.
Width: 12 inches
Depth: 2 inches
Height: 14.25 inches
