k_olson
May 09, 2017Aspirant
R7800 - DL speed 1/3 that of UL Speed over WiFi
Hello! I've recently upgraded to gigabit fiber in my home and as a result, have upgraded my network hardware. I have an Ubiquiti Edgerouter Lite feeding a brand new R7800 in AP mode. Connected via et...
- May 15, 2017
Thanks for that suggestion. Might be worth a shot.
After trying the Synology and Unifi AC HD and getting essentially identical performance from all three, I'm thinking this could be some sort of limitation of my computer. As a result, both the Synology and Unifi were sent back and I'll plan to keep the R7800 for the forseeable future. So trying out 3rd party FW seems like a logical next step to try when I have time.
netwrks
May 10, 2017Master
I'd start with the obvious stuff..
Enable WMM
Disable HT160 (if it's enabled) and re-test.
Disable MU-MIMO (if it's enabled) and re-test.
I'm going to assume it's nothing on the Mac side, that is giving you grief..
Are you able to run iperf between your Mac and another wireless client or a wired 1000Mbps client to check throughput? (as opposed to running a speedtest).
Another thing to try, is run the 7800 in router mode, but disable DHCP etc, (give the 7800 a static IP Address) to see if that improves your throughput.. There was a bug on some of hte R Series routers, where in AP mode (and plugged into the WAN port),would casue throughput degerdation. Not sure if the 7800 suffers from this problem, but you could try this, as a last resort.
Or... get a Unifi AP HD!
k_olson
May 10, 2017Aspirant
Hi netwrks. Thanks for the help. I tried basically everything you mentioned with exactly the same results each time.
- HT 160 is already disabled
- Disabled MU-MIMO with no effect
- Tried iPerf3 with one gigabit computer connected via eithernet and the other new MacBook Pro via 5Ghz wifi and it gave me the same results again when the wired machine was the server. When swapped them and the wifi machine was the server, again same results, it was much faster.
- Also tried setting it in router mode. No difference.
I'm stumped. I may check out the Unifi if I can't figure this one out or the Synology gives me the same thing. I'd love to get the R7800 to work, but it seems to be some sort of hardware or software limitation.
- mondenathMay 11, 2017Prodigy
Have tried disabling the traffic monitor.
Someone reported for his x6 he had similar issues with both wired and wireless reporting 450/450mbps. Once he disable the monitor it jumped back to 930+mbps- netwrksMay 11, 2017Master
Disabling traffic monitor, if it can be enabled in AP mode, is a good idea..
EDIT: the wired testing you did, was that directly connected to the ERL, or on the back of the 7800? If you tested wired, connected to the ERL, for giggles, swap out your Ethernet cable between the ERL and 7800.
- k_olsonMay 11, 2017Aspirant
The traffic meter is grayed out in AP mode, so it must be disabled by default, since I can't even select it. Also, the wired testing I did with iPerf was when the wired computer was connected to the back of the R7800.
Still stumped... but that also makes me curious if a similar AP with similar (or nearly identical) hardware would perform any better. Hope to find that out soon.
