k_olson
May 09, 2017Aspirant
R7800 - DL speed 1/3 that of UL Speed over WiFi
Hello! I've recently upgraded to gigabit fiber in my home and as a result, have upgraded my network hardware. I have an Ubiquiti Edgerouter Lite feeding a brand new R7800 in AP mode. Connected via et...
- May 15, 2017
Thanks for that suggestion. Might be worth a shot.
After trying the Synology and Unifi AC HD and getting essentially identical performance from all three, I'm thinking this could be some sort of limitation of my computer. As a result, both the Synology and Unifi were sent back and I'll plan to keep the R7800 for the forseeable future. So trying out 3rd party FW seems like a logical next step to try when I have time.
May 14, 2017Guru - Experienced User
You might try some 3rd party FW and see if the problem follows. If it does, I'd try another 7800 or replacement unit.
k_olson
May 15, 2017Aspirant
- FURRYe38May 15, 2017Guru - Experienced User
I'm using Voxel's v.30SF version on my R7800 thats over on OpenRouter.
