infael
May 24, 2021Aspirant
R7800 - setting up multiple SSIDs
I looked in the R7800 user guide but couldn't seem to find a way to setup multiple SSIDs. How do I do this? Thanks Mike
infael
I only need 1 separate. Now that I know it can be done, I'll look at the manual more closely. Thanks!
infael
May 30, 2021Aspirant
I couldn't find info on creating multiple SSIDs in the R7800 manual. How can I create another SSID?
TIA
infael
- antinodeMay 30, 2021Guru
> [...] How do I do this? [...]
Why do you want to?
> You can have a seperate SSID for the primary 2.4 GHz band and for the
> primary 5 GHz band. [...]Never trust a man who misspells "separate", I always say.
What he might have meant was that the 2.4GHz radio and the 5GHz radio
can have different SSIDs (different from each other).For the 2.4GHz radio, you can have one normal SSID and, optionally,
one "guest" SSID.For the 5GHz radio, you can have one normal SSID and, optionally,
one "guest" SSID.You can't have multiple normal SSIDs for either radio. At least not
with the Netgear firmware. If you can find third-party firmware for
your model, then you might find more features.- infaelJun 01, 2021Aspirant
I got a smart fridge. I've ead that setting up a separate SSID is one security measure I can take for the fridge.
- antinodeJun 01, 2021Guru
> [...] I've ead that setting up a separate SSID is one security measure
> I can take for the fridge.Configure a "guest network" and have it use that? I wouldn't expect
that to save you from much, but that's what your router can do.
