nickat1
Aug 22, 2022Aspirant
R7800, /23 LAN mask. Config advice to get DHCP pool & GW at either ends of the subnet. Voxel f/w.
Hi, I have an R7800. I've configured a /23 mask for the LAN. I would like my router ip/gateway to be in the bottom half of the subnet and the DHCP pool to be in the uppper half. In the GUI I can only...
Kitsap
Aug 22, 2022Master
In case you have not already discovered it:
https://www.snbforums.com/forums/netgear-ac-wireless.53/
- nickat1Aug 22, 2022Aspirant
Thanks, I'll check it out.
