Zidar
Jul 11, 2017Aspirant
R7800 2,4 GHz is not working, but 5 GHz is fine. (I don´t see 2,4 Ghz on my devices).
Hi, I have R7800 3 weeks. All was fine but two days ago began problem with 2.4 GHz (without upgrades/configurations). I don't see 2,4 GHz on my devices (5 GHz is fine). I did a reset on the route...
- Jul 16, 2017
Hi Zidar,
Try changing the channel of the 2.4Ghz network.
Make sure SSID broadcast is checked.
michaelkenward
Jul 12, 2017Guru - Experienced User
Did you find this?
Generic, but a place to start.
Zidar
Jul 12, 2017Aspirant
Yes, I did. The WiFi LEDs still light.
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi Zidar,
- JamesGLJul 19, 2017NETGEAR Employee Retired
Hi Zidar,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance. - ZidarJul 25, 2017Aspirant
THX,
I changed the channel of the 2.4Ghz network and all is OK. :-)
The problem is when I set channel to auto channel.- michaelkenwardJul 25, 2017Guru - Experienced UserWell done. You aren't the first person to stumble across that one.
It would be interesting to know why the "auto" setting can cause problems. Maybe it is because of local interference, or because with wifi clients have problems.
