XRay_
Aug 10, 2018Aspirant
R7800 400mbps Spectrum not getting more than 75mbps
My ISP network speed is 400 mbps and is being sent as 503 mbps. www.speedtest.net shows a result of 46.70. Why is the speedtest not accurate. I'm hard wired and not using WIFI. I'm using Windows 10 P...
- Aug 10, 2018
What do you see if you connect a computer directly to your modem? That will eliminate the router from the equation.
If possible, you should choose a speedtest.net location run by your ISP and physically close to you. In addition, the speedtest.net app for Windows works better than the browser version. My ISP service is 1 Gbps down and 50 Mbps up. When I test to the speedtest.net site provided by my local ISP in my city at 6:00 am, I routinely see 920 Mbps down when connected to an Ethernet port on the R7800. If I connect to some random speedtest.net site in another city, however, I might only see 200 Mbps down or less, which has do to with how the ISPs interconnect to each other, how much Internet bandwidth each has, and how congested things are at that time (e.g., many small ISP's have only 1/10th of the Internet bandwidth that they sell).
pec967
Aug 10, 2018Luminary
XRay_
Aug 11, 2018Aspirant
Today, I ran speedtest on my PC and got a download of 307 mbps. On the website of my ISP, I got 58 mbps.
Appears I'm not having bandwidth issues and speedtest is just not an accurate means to test bandwidth.
