RichS1
Jul 02, 2021Follower
R7800 Access Control - Solved for me
I've been having trouble adding new devices to my R7800 router, but I think I solved the problem for me. You can jump to that down at the bottom if you don't want to read the entire post. Firm...
antinode
Jul 02, 2021Guru
> [...] will probably turn on the Randomized option when/if I connect to
> a public network.
On iOS, the similar feature is enabled/disabled by SSID.
