Funbeads21
Sep 26, 2023Aspirant
R7800 Access Denied error on some websites.
I have had problems since I setup my R7800 router. When I tried to connect to some websites, I get an error message. One example is when trying to connect to Southwest.com I get the following error "...
Funbeads21
Sep 27, 2023Aspirant
I get the same error with several websites on all devices. I have had issues with some streaming services not connecting too.
My R7800 has been updated to the latest firmware Version V1.0.2.92
My service provider is Xfinity
I use my own Arris SB8200 modem
I have restarted both modem and router several times.
I have cleared my history and cache.
I was using a NG R7500v2 and had had no problem going to any websites
Most websites work fine but there are those that just throw the following error
Access Denied
You don't have permission to access "http://www.southwest.com/" on this server.
Reference #18.8cbc6e68.1695824681.13ce0007
Thank you for your interest in my problem. Hopefully you can suggest a solution to solve this problem.
Sep 27, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Armor, Smart Parental Controls or Circle
