garethr's avatar
garethr
Tutor
Mar 23, 2016
R7800 and iOS compatible OpenVPN
Anyone have any idea when we're likely to see iOS support for OpenVPN on the R7800 land - I see other models are slowly getting the update (including the R7000 - a much older model), so wondered when the R7800 is going to be in line for this update?
  • Hi garethr,
    You may check our support site for any available firmware. Release notes are available as well together with the firmware for any updates or added features that users wants to know.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi garethr,
    Let me check on your inquiry and will give you and update.
  • JamesGL's avatar
    JamesGL
    Hi garethr,
    The OpenVPN for mobile clients will be supported in R7800 but no ETA yet when it will be available.
    • garethr's avatar
      garethr
      Tutor
      Thanks for the update. I've also been told by a Netgear rep on another forum that depending on how QA goes this release could be within the next few weeks.
      • JamesGL's avatar
        JamesGL
        Hi garethr,
