Jbenhart
Oct 27, 2022Guide
r7800 and Powerline v1 2nd Port Complete Disconnect
Hello all, I have a new one for you, I bet. I have a r7800 and a powerline ethernet adapter (tk1000 ver 1, I believe). It has two ports on it, and I am successfully using the first port, no probl...
- Oct 27, 2022
Jbenhart wrote:
Don't I have have to plug both ports from one plug into the router and both eth wires (computer and tv) into the other plug?
Not in my experience.
When I use two-plug Powerline adaptors I have just one connection to the router – from a single-port plug. Then I can run two separate devces from the second two-port plug.
Jbenhart
Oct 27, 2022Guide
It is a TP-LINK AV1000 2-Port Gigabit model TL-PA7020 ver 1. Each plug-in has two Ethernet ports. Don't I have have to plug both ports from one plug into the router and both eth wires (computer and tv) into the other plug?
michaelkenward
Oct 27, 2022Guru - Experienced User
