perseid's avatar
perseid
R7800 as extender?
Hi all, I've been using the Nighthawk X4S R7800 as my main Wifi router but I replaced it with the RAXE500. I plan to use the R7800 to extend the range from the RAXE500  in areas of my house where signal is weak or null. I'm a bit confused as to all different modes: AP, Bridge, Extender. The idea is to have the R7800 in wireless mode (not cabled to the RAXE500), and to maintain the same SSID so that devices that connect wirelessly do so in smart roaming mode (automatically hop to the strongest signal router as I walk from one place to another). I'd appreciate your help so to achieve this, thanks
  • FURRYe38's avatar
    The R7800 only supports Router, AP or Bridge(wireless client) modes. It doesn't support Extender mode.
    • perseid's avatar
      perseid
      Yes I read that Extender mode is not supported in the R7800. Will AP or Bridge mode work the way I described?
      • plemans's avatar
        No.
        Ap mode it needs to be hardwired in.
        Bridge mode doesn't rebroadcast. Its designed to use the wireless as a "bridge" from router to router with the 2nd one being able to use its ethernet ports but not rebroadcast its wifi.
        You could always use it in ap mode and connect it using powerline or moca adapters if you didn't have an ethernet connection
        There is some aftermarket firmware for the R7800 if you do a little googling that might have that capability.
