HakanD's avatar
HakanD
Follower
Mar 24, 2021
R7800 as wifi repeater
Since I got an R7800 over I tried to configure it as a (somewhat expensive) wifi repeater. Found this link https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-rou...
  • plemans's avatar
    Mar 24, 2021
    There isn't a repeating/extender mode on that router.
    The article has an "applies to" list and the R7800 isn't on there.
    You can use it in access point mode and try hardwiring it in with ethernet, moca adapters, or powerline.
    Or you can check with some of the 3rd party firmwares out there. Potentially they support repeater/extender mode. Keep in mind 3rd party firmwares can brick your device and they void the warranty.
