eghanson
Oct 10, 2021Aspirant
R7800 assigned duplicate ip address
Today I had a static IP address assigned to an Ethernet connected computer also assigned to a WiFi connected TV by the R7800 with the latest update. This assignment caused a DNS error on the computer because the IP address assigned on the computer due to the duplication was not a valid IP address for my network. I fixed the issue by disconnecting the tv power and then restarted the tv and staticly assigned the new IP address to the tv on the router. The router should never assign a static IP address to another device than the device assigned to the static IP address. I have never had this happen before. Restarting they router did not fix the problem.
- eghansonAspirant
I should have said that I Reserved the IP address on the router to assign to the device and not that I staticly assigned the IP address on the device. So the router should have used the Reserved IP address that I Added on the router and not used that IP address to assign to another device. All devices are using DHCP.
After you do the IP address reservation ON the router for your devices, are you rebooting the router and your devices?
