userlee1983
Dec 19, 2022Aspirant
r7800 cannot connect
Hello I have bought a r7800 set up and turned on and I can't connect using said WiFi password. Did factory reset still can't connect. And sometimes power led goes solid orange
userlee1983
Won't connect either by ethernet cable either. Won't connect via the link to the router given in the instruction manual.
Any ideas
Any ideas
userlee1983
Need to connect to gui to change settings for sky internet option61.
