userlee1983
Dec 19, 2022Aspirant
r7800 cannot connect
Hello I have bought a r7800 set up and turned on and I can't connect using said WiFi password. Did factory reset still can't connect. And sometimes power led goes solid orange
michaelkenward
Dec 20, 2022Guru - Experienced User
That's worrying. What does it look like now?
Could be a sign that the firmware is playing up.
If you can get into the thing, it might be worth reflashing the firmware.
The next step would be to throw TFTP at it.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Kitsap has covered just about everything else you are likely to come across.
Does this get you anywhere?
http://routerlogin.com/debug.htm
userlee1983
Dec 20, 2022Aspirant
I think the problem lies within not being able to connect at all.
Once I enter the WiFi password it just hangs on connecting.
When I click on information it says connect awaiting IP address and that's as far as it gets it never ever connects and says connected to the SSID
And on ethernet it just says not connection.
- michaelkenwardDec 20, 2022Guru - Experienced User
userlee1983 wrote:
And on ethernet it just says not connection.There can be various reasons for that.
What says "not connection"? What is the exact message?
From what? A PC? Windows?
And the colour of that power LED?
When I click on information it says connect awaiting IP address and that's as far as it gets it never ever connects and says connected to the SSIDConnecting from what wifi client and with what? A browser? An app?
Troubleshooting needs these things is a systematic and methodical approach, taking one step at a time in the right order.
- userlee1983Dec 20, 2022AspirantPower light is now white constantly
When I get on laptop and phone there is a small I by the connection. When I click that it says connection status obtaining IP address and that's as far as I get.
It doesn't say like usual connected to Netgear router as it should. And it doesn't show as connect to router on laptop or phone
And sometimes the router isn't even picked up by my phone or laptop wirelessly or ether net- michaelkenwardDec 20, 2022Guru - Experienced User
userlee1983 wrote:
When I get on laptop and phone there is a small I by the connection. When I click that it says connection status obtaining IP address and that's as far as I get.And that is an icon somewhere?
The Windows notification area?
Have you tried the Network Troubleshooter in Windows?
