userlee1983
Dec 19, 2022Aspirant
r7800 cannot connect
Hello I have bought a r7800 set up and turned on and I can't connect using said WiFi password. Did factory reset still can't connect. And sometimes power led goes solid orange
userlee1983
Dec 20, 2022Aspirant
I think the problem lies within not being able to connect at all.
Once I enter the WiFi password it just hangs on connecting.
When I click on information it says connect awaiting IP address and that's as far as it gets it never ever connects and says connected to the SSID
And on ethernet it just says not connection.
michaelkenward
Dec 20, 2022Guru - Experienced User
There can be various reasons for that.
What says "not connection"? What is the exact message?
From what? A PC? Windows?
And the colour of that power LED?
Connecting from what wifi client and with what? A browser? An app?
Troubleshooting needs these things is a systematic and methodical approach, taking one step at a time in the right order.
