Kestrel1
Oct 03, 2021Aspirant
R7800 cannot get IP from Xfinity
Yesterday, our R7800 router spontaneously lost Internet twice from Xfinity. The first time, it came back 15 minutes after a modem/router power cycle. The second time it stayed down and will not come b...
- Oct 04, 2021Well, I found a solution sort of.
I pretty much gave up and tried the last thing I could think of: Reset to factory defaults.
I then reconfigured the router from scratch with the exact same settings I used before. I instantly connected online.
No idea what the cause was, I can only assume some kind of software fault or corrupted config file. In any event, I guess I don’t need a new router.
Kestrel1
Oct 04, 2021Aspirant
