esheyw
Aug 29, 2021Follower
R7800 cannot hit the tftp window
I have been trying to tftp new firmware to my r7800, and I simply cannot get it to do anything but connect request failed on me. I am plugged in via Ethernet, I have a static up set on the uploading c...
michaelkenward
Aug 30, 2021Guru - Experienced User
As plemans says, TFTP is sensitive.
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
