JRKei
Aug 11, 2023Aspirant
R7800 Connected Device List
I've been using my R7800 for about 7 months. It was easy to set up and everything works as I would expect. Detected internet speed is 108 meg which is as it should be. My issue is with the listing o...
JRKei
Thank you for the reply. I used the MAC lookup sites as well as just submitting the OUI information in another database. The result was the MAC and OUI were not in any database. Apparently this is caused for two reasons. #1. The manufacturer chose to not register. #2. The manufacturer IS registered, but makes their own MAC which may not conform to IEEE or anyone but themselves. All of my known 41 devices are accounted for except for the two missing from the list. Both of them are TPLink and entering their MAC addresses in the MAC lookup sites results in positive identification.
As for the two missing devices your description of Netgear being woefully caviler about their software/firmware I'm guessing that these two seperate, but related issues will remain unresolved. Perhaps when another firmware upgrade comes down the pike I can expect (ha ha) improvements.
michaelkenward
Aug 12, 2023Guru - Experienced User
There is a third possible reason. Apple, Samsung and Microsoft have taken to using what they consider to be an extra security measure by assigning random mac addresses to things.
Here's a local note on what can happen in mobile phones:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
I have no idea how these randomised addresses would play on the lookup sites.
The R7800 does get firmware updates, but nothing of much substance, mostly security. This is an excellent but ageing (2017) router.
I have no idea how my R7800 handles attached devices. It isn't something that worries me. I use the desktop genie to keep track of, and access, devices on my small network.
