cjs14
Mar 31, 2022Star
R7800 defaults after power outage
Had an issue a few months back (kudos to plemans and michaelkenward for their assistance!!!) where CM1000 and R7800 needed reboot daily due to poor cable wiring. Got that corrected with new ISP run f...
Mar 31, 2022Guru - Experienced User
something might have gotten corrupt in the firmware.
I'd try reinstalling the firmware, then do a factory reset and clean install (in case its something in the settings/backup settings corrupt)
cjs14
Apr 01, 2022Star
Thanks, I'll give that a try this weekend. Thanks again for the help with the connectivity issue, signal was stable after ISP replaced the cable from the street but was still too hot, adding a 12db pad seems to have solved the problem.
