cjs14
Mar 31, 2022Star
R7800 defaults after power outage
Had an issue a few months back (kudos to plemans and michaelkenward for their assistance!!!) where CM1000 and R7800 needed reboot daily due to poor cable wiring. Got that corrected with new ISP run f...
Mar 31, 2022Guru - Experienced User
something might have gotten corrupt in the firmware.
I'd try reinstalling the firmware, then do a factory reset and clean install (in case its something in the settings/backup settings corrupt)
cjs14
Apr 22, 2022Star
So I tried your suggestion, reinstalled firmware, then reset (not sure what you mean by clean install, software for remote access?).
Same issue, unplug power for a minute, restart, login and up pops as if booting for the first time, step through assign admin PW, secret questions, etc.
Very frustrating if I'm not home and able to reset for family. Appreciate any other suggestions.
Thanks!
