simon1893's avatar
simon1893
Follower
Jan 24, 2021
R7800 doesn't send WIFI Signal
Hi guys, as you can see my router doesnt send the WIFI Signal although it is activated in the settings. It worked fine until now, as the 2.4 Ghz and 5 Ghz lights didnt start blinking anymore when the router started... what can I do?
  • On the front of the router, the last two LED's on the right side are a combination indicator/switch.  You have most likely managed to manually turn off the Wi-Fi.  With the router powered on, press and release the LED second from the right.  Give it a few seconds to power up after you have released the switch.
    • labatt's avatar
      labatt
      Mentor
      Cats love to lay on routers as they are warm. Down side is they may turnoff the wifi.
      • michaelkenward's avatar
        michaelkenward
        Toddlers are also good at pressing shiny buttons.
