simon1893
Jan 24, 2021Follower
R7800 doesn't send WIFI Signal
Hi guys, as you can see my router doesnt send the WIFI Signal although it is activated in the settings. It worked fine until now, as the 2.4 Ghz and 5 Ghz lights didnt start blinking anymore when the...
Kitsap
Jan 24, 2021Master
On the front of the router, the last two LED's on the right side are a combination indicator/switch. You have most likely managed to manually turn off the Wi-Fi. With the router powered on, press and release the LED second from the right. Give it a few seconds to power up after you have released the switch.
- labattJan 24, 2021Mentor
Cats love to lay on routers as they are warm. Down side is they may turnoff the wifi.
- michaelkenwardJan 25, 2021Guru - Experienced User
Toddlers are also good at pressing shiny buttons.
