simon1893
Jan 24, 2021Follower
R7800 doesn't send WIFI Signal
Hi guys, as you can see my router doesnt send the WIFI Signal although it is activated in the settings. It worked fine until now, as the 2.4 Ghz and 5 Ghz lights didnt start blinking anymore when the...
labatt
Jan 24, 2021Mentor
Cats love to lay on routers as they are warm. Down side is they may turnoff the wifi.
michaelkenward
Jan 25, 2021Guru - Experienced User
Toddlers are also good at pressing shiny buttons.
