Filip_Serlet
Mar 24, 2020Aspirant
R7800 drops internet connection on ethernet cabled connection (not on wifi)
I've been experiencing this problem for several months now and it is most annoying. Every day at the exact same time (17h27 and 20h34 and some days also at 13h45), the router R7800 drops the interne...
- Apr 24, 2020
Hi Filip_Serlet.
I had a similar problem with my R7800 in January.
Like you, I am not using my R7800 in the usual router mode. I have mine set up as a wireless bridge, not as an access point. Every few days all the wired Ethernet devices connected to the R7800 would report that they no longer had a network connection. However, the 5GHz wifi link from the R7800 to the modem/router would always remain up when this happened and I could still connect to the R7800's admin web interface across the LAN. The only way I could get the disconnected wired devices back on the network was to power cycle the R7800.
My problems started immediately after I updated to firmware 1.0.2.68. A factory reset can sometimes fix problems after a firmware update but it didn't fix this. Eventually I gave up and reverted to firmware 1.0.2.62 and everything has been fine again since then.
It's been a couple of weeks since your previous post. Have you found a way to make 1.0.2.68 work reliably in AP mode with wired connections?
Filip_Serlet
Thanks for your reply.
Currently, the router is running on system software V1.0.2.68. I am using is as an Access Point.
The modem is from a Belgian internet provider (Proximus), country where I live. I found this reference on the label: "Sagemcom Modem ADSL/VDSL2/TV PSTN b-box 3V+" and also "P/N: 253670439".
I will do as you suggest: restore to factory settings and restart again. Then update to the latest firmware (mentioned above).
Then I will have to wait a day to see if the internet gets blocked again. I will send feedback on the progress tomorrow (in Belgium it is now 15h00).
Filip_Serlet
Mar 26, 2020Aspirant
Result of reset to factory settings.
So I did a reset to factory settings using the Netgear interface. I noticed that the router remained on the current firmware version V1.0.2.68 (it did not return to the initial firmware at purchase).
Unfortunately, this did not solve the problem. Yesterday at Belgian time 16h55, the internet connection on the wired pc was blocked again as before. So I switched it to wi-fi for the rest of the day.
I also had some trouble with the wi-fi af few minutes afterwards (but not related to the wired internet blocking problem), so I had to restart the router.
You can find the router loggings here below starting from that restart.
Every 30 minutes, and sometimes every 90 or 120 minutes, there is a statement "internet connected". Could this have something to do with the timeframes where the internet is being blocked on the wired machines? I will try to monitor this today.
I have also seen that a lot of functions in the router GUI are disabled, and cannot be enabled. E.g. Traffic Meter, UPnp and IPv6 in the Advanced Settings.
***loggings*****
[admin login] from source 192.168.1.32, Thursday, March 26, 2020 09:46:56
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 09:36:50
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 09:06:49
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 08:36:49
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 08:06:48
[admin login] from source 192.168.1.32, Thursday, March 26, 2020 07:58:47
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 07:06:47
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 05:06:45
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 02:36:45
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 01:06:44
[Internet connected] IP address: 192.168.1.2, Thursday, March 26, 2020 00:36:43
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 22:36:42
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 20:36:42
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 20:06:41
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 19:36:42
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 19:06:42
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 18:36:42
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 18:06:41
[admin login] from source 192.168.1.57, Wednesday, March 25, 2020 18:01:05
[admin login] from source 192.168.1.57, Wednesday, March 25, 2020 17:51:44
[admin login] from source 192.168.1.57, Wednesday, March 25, 2020 17:40:11
[admin login failure] from source 192.168.1.57, Wednesday, March 25, 2020 17:40:05
[Internet connected] IP address: 192.168.1.2, Wednesday, March 25, 2020 17:36:41
[admin login] from source 192.168.1.57, Wednesday, March 25, 2020 17:25:07
[Time synchronized with NTP server] Wednesday, March 25, 2020 17:06:58
[Initialized, firmware version: V1.0.2.68] Wednesday, March 25, 2020 17:06:57
- plemansMar 26, 2020Guru - Experienced User
The b-box 3v+ is a modem router combo device.
has it been placed in passthrough modem only mode? Or the R7800 in AP mode?
Otherwise you're running 2 routers together which puts you in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
- Filip_SerletMar 26, 2020Aspirant
Hi there.
The bbox-3 is indeed a modem/router from my ISP, which I could not set to bridge mode as suggested in the knowledge base article you reffered to. I disabled the wi-fi on the modem router (from the start) and it is only wired to my Netgear router and to my TV decoder.
My Netgear R7800 has been set to AP mode when the bbox-3 was installed (about 2 years ago).
So I suppose it is not a NAT-issue?
If you run directly off the modem/router device, does the issue still happen?
