Filip_Serlet
Mar 24, 2020Aspirant
R7800 drops internet connection on ethernet cabled connection (not on wifi)
I've been experiencing this problem for several months now and it is most annoying. Every day at the exact same time (17h27 and 20h34 and some days also at 13h45), the router R7800 drops the interne...
- Apr 25, 2020
Hi Filip_Serlet.
I had a similar problem with my R7800 in January.
Like you, I am not using my R7800 in the usual router mode. I have mine set up as a wireless bridge, not as an access point. Every few days all the wired Ethernet devices connected to the R7800 would report that they no longer had a network connection. However, the 5GHz wifi link from the R7800 to the modem/router would always remain up when this happened and I could still connect to the R7800's admin web interface across the LAN. The only way I could get the disconnected wired devices back on the network was to power cycle the R7800.
My problems started immediately after I updated to firmware 1.0.2.68. A factory reset can sometimes fix problems after a firmware update but it didn't fix this. Eventually I gave up and reverted to firmware 1.0.2.62 and everything has been fine again since then.
It's been a couple of weeks since your previous post. Have you found a way to make 1.0.2.68 work reliably in AP mode with wired connections?
Filip_Serlet
Apr 10, 2020Aspirant
Hi there. I checked the wired connection between the bbox router and the R7800 AP.
On the bbox router, the ethernet cable is in a LAN-port (not in the WAN-port).
On the R7800 AP, the ethernet cable coming from the bbox router is in the port labeled "Internet" (next to the 4 LAN-ports labeled 1 to 4).
moopig
Apr 25, 2020Apprentice
Hi Filip_Serlet.
