Andydie
Mar 03, 2022Aspirant
R7800 error during firmware update "MD5 verify error."
Hi during the update of the latest firmware the router is unable to download it for the update and returns the following error "MD5 verify error." I manually downloaded the firmware and the manual u...
Mar 04, 2022Guru - Experienced User
Can you re-check this? I got word from NG that this was fixed on there side.
I manually downloaded the firmware and the manual update was successful.
But now the router signals me an update for the “GUI Language” firmware, this too fails to update it for the same reason "MD5 verify error.".
I would like to carry out the manual update but on the site I cannot find where to download this type of update "GUI Language V1.0.0.423".
Does anyone know how to fix the "MD5 verify error." Or where to manually download the update?
Thank you
- AndydieMar 05, 2022Aspirant
Hi FURRYe38,
Thanks for the replies, but unfortunately I still have the same issue.
I also performed the factory reset, as suggested on the post suggested, with no solution.
I also encountered another issue, that now the router no longer allows changing the language, trying to change the language the GUI always returns to English.
- FURRYe38Mar 05, 2022Guru - Experienced User
Thanks for letting us know.
