DV-NightHawk
Jan 30, 2022Aspirant
R7800 eSATA LED on, no Wi-Fi, LAN OK
My R7800 suddenly showed a white eSATA LED. no Wi-FI Connection anymore and i cannot connect to the 192.168.1.1 anymore, even not with a cable.So the login towards the router is gone If i connect th...
wcalifas
Jan 30, 2022Prodigy
Try pressing the wifi LED on the right hand side of the LED'S (the 2nd LED) on the right hand side for 2 seconds. See if it turns the wifi back on. If that doesn't work power cycle your router and see if the wifi comes back on. If it doesn't you can do a hard reset where you press the reset pinhole for 30 seconds with a paper clip while your router is on, that will reset your router back to factory default like when you used it the first time. Let us know what happens.
- DV-NightHawkJan 30, 2022Aspirant
Tried all that, nothing helps
when powering on via the on-/off switch: eSATA lights up white, port 1,2,3,4 pinkish, all for 1s, then eSATA stays on, bright white
The 2.4 and 5GHz LEDs light up very dimmed
- michaelkenwardJan 30, 2022Guru - Experienced User
Had any thunderstorms lately?
What colour is the power LED?
What firmware version is installed?
How about a recovery reset?
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
- KitsapJan 30, 2022Master
If you have made it this far without success, there is a chance the firmware on your router has become corrupted. Any type of a power glitch or interruption may be the cause.
If you have access to the GUI, download a fresh copy of the firmware and flash it over the top of the existing. Do a reset and configure from scratch. Some of your settings may also be corrupted.
If there is a newer version of the firmware available, that is also an option.
Since you have an R7800, you also have the option of Voxel firmware (refined Netgear). See here: http://www.voxel-firmware.com/Downloads/Voxel/html/index.html
