thompsondc
Nov 07, 2021Tutor
R7800 Ethernet doesn't work after updating to Firmware Version 1.0.2.86
After updating to firmware 1.0.2.86, and several reboots, reconnections, flushes, etc, ethernet ports on r7800 don't work. All of the aforementioned efforts got the wifi working again, but not wired c...
- Nov 24, 2021
Thanks for the update. Sounds like you were not able to obtain the Ubiquiti ER-10x. Don't let the Voxel firmware option escape from your list of possible solutions.
thompsondc wrote:
Update: because of the supply chain issues, I'm going to opt for a microtik or tp-link router that's vlan capable. Then I'll use my old Linksys routers as access points. If I need a 3rd access point, I'll use this x4s as an AP only
thompsondc
Nov 11, 2021Tutor
RJ45 ports (Ethernet) not working again. Happy veterans day! Thanks Netgear. You suck.
Nov 11, 2021Guru - Experienced User
What happens if you load up Voxels FW?
- thompsondcNov 12, 2021TutorI haven't tried it. Honestly, my work computer and my wife's are dependent upon the router working. Because the wireless is still working, we're getting by. I've already purchased a Ubiquiti ER-10x that I'm waiting for. Once i have it, the Netgear will be disposable and i can try flashing other firmware. Right now we're just in limbo. It really is annoying, as it Plex server is on a NAS that is wired only, so it's unusable (the Netgear won't even do basic routing along the wired devices).
- thompsondcNov 24, 2021TutorUpdate: because of the supply chain issues, I'm going to opt for a microtik or tp-link router that's vlan capable. Then I'll use my old Linksys routers as access points. If I need a 3rd access point, I'll use this x4s as an AP only
- KitsapNov 24, 2021Master
