thompsondc
Nov 07, 2021Tutor
R7800 Ethernet doesn't work after updating to Firmware Version 1.0.2.86
After updating to firmware 1.0.2.86, and several reboots, reconnections, flushes, etc, ethernet ports on r7800 don't work. All of the aforementioned efforts got the wifi working again, but not wired c...
- Nov 24, 2021
Thanks for the update. Sounds like you were not able to obtain the Ubiquiti ER-10x. Don't let the Voxel firmware option escape from your list of possible solutions.
thompsondc wrote:
Update: because of the supply chain issues, I'm going to opt for a microtik or tp-link router that's vlan capable. Then I'll use my old Linksys routers as access points. If I need a 3rd access point, I'll use this x4s as an AP only
thompsondc
Nov 24, 2021Tutor
Kitsap
Nov 24, 2021Master
- thompsondcNov 25, 2021Tutor
I'll give it a try. I think I'm going to get a Microtik. I still want to segregate my home network, and since I found a second extra old linksys, the netgear is completely disposable. I can do what I want with it, including flashing it with new firmware.
