elevateX
May 25, 2018Follower
R7800 Firmware Bug
Hi,
Just upgraded to firmward V1.0.2.52 on my R7800. All of the names of my "Attached Devices" were erased. Now, when I enter a name for a device and select save, the name is not remembered. Ple...
- Sep 02, 2018
Hi All,
A new firmware is being released for this model and fixes for attached devices issue is included. Here's the release notes:
https://kb.netgear.com/000059692/R7800-Firmware-Version-1-0-2-58
Blanca
Community Team
Ken54
May 26, 2018Guide
I had the same thing happen with V1.0.2.52 after upgrade. I have also experienced disconnects from the router every 15-20 minutes with the new verion. I have reverted back to V1.0.2.46 and will monitor for stabillity issues then try to get back to you about my suspicion that V1.0.2.52 is buggy.
avtella
May 26, 2018Prodigy
No issues regarding WiFi here in my testing so far. Try factory reset and don’t use backup config, as in manually reconfigure. Sometimes changes can cause issues with old configs.
