rbird2
Oct 09, 2017Luminary
R7800 firmware update 1.0.2.36 broke Network Drive - unable to make backups.
Well I unfortunately upgraded to the "Netgear R7800-V1.0.2.36" firmware and found it broke Readyshare with my WD 1TB eSATA drive connected to my R7800. Using Macrium Reflect I was unable to make a ba...
- Nov 24, 2017
Netgear has finally released R7800 firmware version 1.0.2.38 that fixes the Network Drive bug introduced in the version 1.0.2.36 firmware:
http://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.38.zip
AhnFire
Nov 27, 2017Guide
Confirmed .38 fixed the network issue.
Also, the WIFI krack... doesn't that require the whole WIFI consortium to update the protocol? I don't think Netgear can solve it on their own.
- knodiNov 27, 2017Guide
Other vendors have already rolled out a fix for KRACK, its only Netgear and few other **bleep** vendor that are lagging behind.
- michaelkenwardNov 27, 2017Guru - Experienced User
Which vendors do you have in mind? I see complaints like this elsewhere. Who has fixed it?
Netgear has released some updates. You may have to check for them.
Actually, this is much less of an issue for Netgear than it is for most of the tech sector. KRACK is really all about wifi clients. (I have read the original research paper from Leuven.)
With routers and modems you have to put them into bridge mode to make them vulnerable. Have you done that?
If your router is working simply as a router or your modem is just a gateway (modem/router) it won't affect you.
The people who really need to fix this are Apple and Google (Android). But I guess it is harder to be rude about them.
Until they do, I suggest that you wrap all your tablets and mobile phones in tin foil.
- rbird2Nov 27, 2017Luminary
Updated List of WPA-2 KRACK Patches in Consumer Routers (Last Updated 22-Nov-2017):
https://www.macobserver.com/news/list-of-krack-patches-routers/
