rhodess
Oct 27, 2019Aspirant
R7800 firmware update to v1.02.62 caused internet connection to stop working
Model - R7800 nighthawk I updated the firmware yesterday from v1.0.2.5x to v1.0.2.62. Immediately following the update to the firmware the router could no longer see the modem. I swapped out cab...
- Oct 27, 2019
I have found the following steps to work with two different R7800 routers connected to Comcast XB6 Gateways that are set in bridge mode.
The sequence of the following steps is important for success. Download and flash the v1.02.63 hotfix firmware on your router.
Through the graphical user interface, go to Advanced -> Administration -> Backup Settings and revert to factory default settings.When the router restarts, be sure and go to Advanced -> Administration -> Firmware Update and set the I disagree to router auto firmware update option.
Disconnect the power from your router.
Disconnect the power form your modem.
Wait a minimum of 20 minutes.
Reconnect the power to your modem and give it enough time to fully start up and connect to your service provider. Estimate five to ten minutes.
Reconnect the power and turn on your router. The Internet connected LED should turn white as the final step of the boot process.
Kitsap
Oct 27, 2019Master
- rhodessOct 27, 2019Aspirant
That did it (after two passes a the process).
What problem did that solve? Do you have details on the source of the issue?
Thank you for the quick assistance. Much appreciated!
- KitsapOct 27, 2019Master
Not sure exactly what it solves. The internet connection between the router and the gateway seems to be difficult to estabish when you make changes and reboot too many times too quickly.
This comes from experience with several years of updating firmware or swapping various ASUS and Netgear routers connected to different Comcast gateways.
- michaelkenwardOct 28, 2019Guru - Experienced User
20 minutes is far too long.
This is the usual advice for rebooting a network:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
You can usually time things by looking at the LEDs on the devices.
- KitsapOct 28, 2019Master
You missed the point entirely. The 20 minute wait is while the device is completely disconnected from power.
Two minutes is not sufficient for a Comcast gateway to boot and establish connections.
That is not the experience of many users.
But it is easy to miss the point when someone fails to explain why they made that point ion the first place.
It is unwise to make definitive statements on the basis of incomplete information.
Who told you that rhodess is a Comcast customer? Or even that they have cable Internet?
