rhodess's avatar
rhodess
R7800 firmware update to v1.02.62 caused internet connection to stop working
Model - R7800 nighthawk   I updated the firmware yesterday from v1.0.2.5x to v1.0.2.62.  Immediately following the update to the firmware the router could no longer see the modem. I swapped out cab...
  • Kitsap's avatar
    Oct 27, 2019
    I have found the following steps to work with two different R7800 routers connected to Comcast XB6 Gateways that are set in bridge mode.
    The sequence of the following steps is important for success. Download and flash the v1.02.63 hotfix firmware on your router.
    Through the graphical user interface, go to Advanced -> Administration -> Backup Settings and revert to factory default settings.
    When the router restarts, be sure and go to Advanced -> Administration -> Firmware Update and set the I disagree to router auto firmware update option.
    Disconnect the power from your router.
    Disconnect the power form your modem.
    Wait a minimum of 20 minutes.
    Reconnect the power to your modem and give it enough time to fully start up and connect to your service provider. Estimate five to ten minutes.
    Reconnect the power and turn on your router.  The Internet connected LED should turn white as the final step of the boot process.
