XRay_
Aug 08, 2022Aspirant
R7800 Firmware v1.0.2.90 loses internet connection during Samsung TV streaming
During straming with a Samsung TV, internet connection continues to get lost. Must reboot TV. Any solution?
Aug 08, 2022Guru - Experienced User
Is the TV wireless connected when streaming?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How is the wireless setting and advanced wireless settings configured on the router?
What is the distance between the router and TV?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
