Bigrbob
Oct 25, 2022Aspirant
R7800 Firmware V1.0.2.92 update messed up readyshare
Nighthawk R7800 Firmware V1.0.2.92 update messed up readyshare. After the reboot the drives show up on the readyshare web screen, but does not show up on filemanagers on my LAN. Linux Mint (2 differe...
- Oct 28, 2022
I rolled it back to 1.0.2.90, now readyshare works as before.
Thanks
wifi_problems
Nov 22, 2022Tutor
I dont understand how rolling back is an accepted solution?
Please keep this issue open so that we can get some answers from Netgear.
- michaelkenwardNov 23, 2022Guru - Experienced User
Not much point in that.
You should know that this community is essentially a user-to-user venue to talk about technical issues, with some input from a small band of Netgear techies.
As you didn't start this conversation, if you want more help you might do better to start a new conversation.
As already explained, you do not need to roll back to older firmware to use ReadySHARE. It works just fine for me with the newest firmware. So it is possibly a problem at the user end.
- wifi_problemsNov 24, 2022Tutor
As already explained, you do not need to roll back to older firmware to use ReadySHARE. It works just fine for me with the newest firmware. So it is possibly a problem at the user end.Would you share steps you used to mount drive in windows/linux?
For me and OP, the old ways of mounting didnt work as soon as upgraded to .92 but downgrading back to .90 worked as before. So clearly there is something wrong with the update.Thanks.
- wifi_problemsNov 22, 2022Tutor
Ever since I updated the FW on R7800 router from .90 to .92, it has been showing few problems
Problem 1: The Readyshare harddisk can not be mounted on both windows and linux machines. I confirmed this by reverting to .90 FW version.
Problem 2: Suddenly not more than approx 20 devices could get internet but do connect to wifi. Again reverting to .90 fixed this.
Following is the Release notes of .92 FW version update and there is no mention on any update related to above problems. Time machine is an apple thing I think and it doesnt affect me.
Enhancements:
- Removed the legacy Time Machine backup feature.
Security Fixes:
- Fixes security vulnerabilities.
Any ideas what has really changed in this FW version and how we can fix the above problems?
