Bigrbob
Oct 25, 2022Aspirant
R7800 Firmware V1.0.2.92 update messed up readyshare
Nighthawk R7800 Firmware V1.0.2.92 update messed up readyshare. After the reboot the drives show up on the readyshare web screen, but does not show up on filemanagers on my LAN. Linux Mint (2 differe...
- Oct 28, 2022
I rolled it back to 1.0.2.90, now readyshare works as before.
Thanks
wifi_problems
Nov 22, 2022Tutor
I dont understand how rolling back is an accepted solution?
Please keep this issue open so that we can get some answers from Netgear.
michaelkenward
Nov 23, 2022Guru - Experienced User
Not much point in that.
You should know that this community is essentially a user-to-user venue to talk about technical issues, with some input from a small band of Netgear techies.
As you didn't start this conversation, if you want more help you might do better to start a new conversation.
As already explained, you do not need to roll back to older firmware to use ReadySHARE. It works just fine for me with the newest firmware. So it is possibly a problem at the user end.
