RangerZ
Sep 04, 2022Aspirant
R7800 FW 1.0.2.90 Unable to enable VPN
I have just promoted a Nighthawk X4S R7800 from AP duty to Router. I have upgraded the firmware to 1.0.2.90 from 1.0.2.46. When I open the menu to configure VPN and click the Apply button I get...
RangerZ
Sep 05, 2022Aspirant
Thank you. So I guess I was miss reading the message, which I interpreted as a "Suggestion". I have not seen this as a requirement with other platforms I have used.
Indirectly related, do you know if the generated OVPN config file also work with the Official OpenVPN Connect, which is already installed, or do I need to use the Community Build?
I'm not onsite so it may not get done for a week or so.
Kitsap
Sep 05, 2022Master
RangerZ wrote:Thank you. So I guess I was miss reading the message, which I interpreted as a "Suggestion". I have not seen this as a requirement with other platforms I have used.
If you take it as a suggestion and it does not work, interpret the other way.
For most setups I have been involved with, the end user either chose a free DDNS service like from Netgear or for reliability chose a paid service like NOIP. Some end users did have a static IP provided by their ISP with the full address, mask, and gateway details provided.
See here: https://kb.netgear.com/23860/How-do-I-set-up-a-NETGEAR-Dynamic-DNS-account-on-my-NETGEAR-router
For windows computers, I use the Community Download programs. For phones/tablets with Android, use the Official OpenVPN Connect from the Play Store.
