Dna316
Jan 29, 2022Aspirant
r7800 fw 1.0.2.90 update now won’t connect to the internet
Last night I backed up my router. Then updated the routers firmare to the latest. 1.0.2.90. Now the router is not connected to the internet. Lan seems fine but no internet. I tried reverting to the ...
Dna316
Also. I can confirm I do have Internet access going straight to the modem
Jan 29, 2022Guru - Experienced User
what modem is it?
- Dna316Jan 29, 2022AspirantComcast x1 gateway.
- Dna316Jan 29, 2022AspirantAlso I just checked the modem and it is in bridge mode so it is allowing the router to handle the addressing.
- plemansJan 29, 2022Guru - Experienced User
Have you tried the x1 in router mode and the R7800 in AP mode?
- Dna316Jan 29, 2022AspirantI have not. I can do that definitely. I would just like to get to the bottom of why the current setup is no longer working after the firmware upgrade.
This same setup hardware and configuration has been running flawlessly for a long time now. It’s just confusing. I wonder if I should downgrade the firmware manually?
