jbusch223
Oct 29, 2019Follower
R7800 how to turn power save features off?
We have a new r7800. There is evidently a power saving feature that turns off the Ethernet ports when there is no activity, and the router must be restarted (or the power button pressed) to activate ...
- Oct 30, 2019
jbusch223 wrote:
We have a new r7800. There is evidently a power saving feature that turns off the Ethernet ports when there is no activity, and the router must be restarted (or the power button pressed) to activate them.
I have seen no sign of this behaviour on my R7800. However, I do know that Windows, for example, has settings that turn off things to save power. Control of that is in Windows itself.
Then again, we don't know anything about what is going on at your end to suggest to you that the R7800 is responsible for whatever it is that you see.
antinode
Oct 29, 2019Guru
> [...] There is evidently a power saving feature that turns off the
> restarted (or the power button pressed) to activate them. [...]
No, "evidently" you have some kind of problem, but that's hardly
evidence of some "a power saving feature" which, I'd guess, is not
mentioned in the documentation of the router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for anything like
what you suspect. Then look for "Troubleshoot".
> [...] We want to turn that feature off, but can't find it in the
> console. [...]
That could be explained easily if there were no such "feature".
> [...] Any help appreciated. [...]
You first? Firmware version? Actual symptoms? How did you
determine that the (LAN?) Ethernet ports have been turned off? As
usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
What about wireless connections?
To what is the WAN/Internet port of the R7800 connected? How do you
know that that device is working?
