StaticFree
Nov 23, 2020Tutor
R7800 in AP mode- cannot access web console from another subnet
I set up the R7800 router in Access Point (AP) mode and have given it a static ipaddress. Also disabled DHCP. It is connected to my network on a VLAN with subnet ipaddress 192.168.100.4. From my p...
StaticFree
Feb 22, 2021Tutor
Whether or not this issue is caused by disabled functions while in AP mode this is a bug that should be fixed by Netgear. I can't believe they still have not addressed this issue.
antinode
Feb 22, 2021Guru
> a static ipaddress. [...]
Ok.
> [...] Also disabled DHCP. [...]
Pointless? Selecting "AP Mode" should do that automatically.
> 404 Not Found
> This server does not support the operation requested by your client.
What, exactly, is looking for what, exactly, (without success)?
> I've searched the internet for this problem and see [...]
Thanks for the helpful links.
> Is there anyone at Netgear that can finally escalate this issue and
> get it fixed?
I'd expect so, but an actual support case is more likely find its
way to any such person than a complaint here is.
I don't generally deal with local VLANs, so I know nothing, and I
can't see what's actually happening in your case, but I wouldn't expect
LAN operations between different subnets to work without involving a
router. Hence, it's not obvious to me that there's actually a problem
(with the router) to be "fixed".
> mode this is a bug that should be fixed by Netgear. [...]
I doubt that the cause (bug or other) is a "disabled function"; more
likely, I'd say, it's some incompatibility between the expectations of
the relevant HTML and those of the user.
> [...] I can't believe they still have not addressed this issue.
That's easy to explain. How many users of this consumer-grade device
do you think might be affected by such a problem? With the backlog of
more common bug-reports which Netgear must have, I'd be amazed if
anything like this ever bubbled to the surface.
