RNASguy
Feb 03, 2022Luminary
R7800 Intermittent disconnects, then auto-reboots
I am about ready to drop this R7800 off the edge of a 20 story building. Two, Three, or more times an hour I get disconnects from the LAN, and the WAN. On the 4 port LAN switch of the R7800 I can...
Feb 03, 2022Guru - Experienced User
You can use Voxels FW on the R7800 as well:
RNASguy
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
https://www.snbforums.com/forums/netgear-ac-wireless.53
Thanks FURRYe38
Re ISP: ATT (crappy, but no choice) residential gateway that provides Uverse via two bonded pair of copper. The copper goes to the vault (a short hop) then goes by fiber (I presume MUX). The RG is: Pace/Arris 5268AC The RG logs show no uncorreted packet errors or lost packets, with low noise and good signal strength. Also good balance on the pair. (I know most of the ATT outside wire guys by first name)
Also note that this RG has been working well and relyably with the R7800 since May 2019
Re Reset: Haven't done that yet, but it is on my option list, along with a few forceful hammer blows to the R7800. The reset will have to wait until I have the time to massage the really poor UI. I have reserved IP list for lots of stuff, and other settings.
I have a back up of the settings but one thought I had was that there might be a conflict with current firmware and some old setting. So if go through with a reset I don't want to just reload an old backup settings. My thinking is that it is better to just go through it page by page. But that will have to wait until I have the time and my fav shot of Whisky near by.
:smileylol:
- RNASguyFeb 03, 2022Luminary
PS: Voxel is a thought, but I have yet to look into it. One question comes to mind: can I reflash the NG firmware if I don't like the Voxel or is it a oneway street.
- plemansFeb 03, 2022Guru - Experienced User
It wouldn't be the first ISP supplied device that got an update that caused issues.
Have you tried the pace in router mode and t he netgear in access point mode?
Hi plemans
Thanks for your post.
Well, not sure what you mean with:
plemans wrote:It wouldn't be the first ISP supplied device that got an update that caused issues.
I regularly look in on the ISP supplied Residential Gateway (Pace/Arris 5268AC) and it has not had an firmware up date in sometime.
The Netgear R7800 on the other has had updates recently in the first of December 2021, and most recently to v1.0.2.90 on the 31st of Jan ‘22.
And as for turning the Pace 5268AC into a router...
plemans wrote:Have you tried the pace in router mode and t he netgear in access point mode?
The Pace already is and must work as a router. As far as I know, there is no “pass through” mode for the Residential Gateway Pace 5268AC. All the services supplied by the RG (TV, voice phone, internet) are coming into the RG as high speed VDSL, and all those services are turned into IP packets in the RG. Therefore the RG must, and will only function as a router so it can route all those packets to the correct service and port on the RG.
To avoid the classic router behind a router problem I changed the subnet on the RG for the LAN side of the RG. I then allowed (in the RG 5268AC) the R7800 access through the RG firewall with DMZplus. This has worked just fine since 2019.
I am starting to think that I should reset the R7800 to factory default, and then page by page do the setup (a big PITB) and NOT load a previous backup setup. Since v1.0.2.82 firmware Netgear removed a bunch of features. It is stuff I don’t use (ReadySHARE Vault, OpenDNS (Live parental controls), remote GUI access, and WPS PIN function) perhaps a reset and a reconfigure is in order.
Thoughts?
PS: how do you like the RAXE500?
